now this turbo cost me nearly 3k and the manifold cost me 1200, so this setup is worth over 4grand and will make easy 800hp at the wheels on your gtr.....
i have no pistures at the moment as this is more of an eoi than a neccesary sale.
the turbo has a single entry 1.06 rear housing and has an elbow welded to the polished compressor housing easy install...
the turbo also has 300dollars worth of water and oil fittings attached..
the manifold is brand new and has never been used and the turbo was on a show car that only ever got driven on and off a trailer so no stress at all... not even seeing boost(kinda sad for a turbo like this) genuine 1000hp GARRETT QUALITY!!!!!
price is $3500 or will trade for some work meisters or other high quality gear for r32 gtr.....
NO CHEAP dream boats PLEASE!!!!!!! if you are a cheap flamin mongrel then stay out of my thread....
apart from that all are welcome to throw me offers thanks
  • Like 1
  • Nope 1
  • 3 weeks later...
Anyone looking please refer to here: http://www.skylinesaustralia.com/forums/topic/346507-gtr-parts-and-tough-good-offsett-wheels/page__p__5602251#entry5602251
There may well be a reason for the delays I am experiencing, and I will happily have my posts deleted the day that I have my money or PFC, but I have made several attempts to contact Chris re this to no avail.
  • 3 weeks later...
Seller has been in touch re the item purchased from another topic, the problem appears to lie with TNT and not RB26DEBT in any way, but I am expecting delivery within a few days..
  • 5 months later...
STILL FORSALE DUE TO TIME WASTERS AND DREAMERS....
if you want a serious turbo setup fort your gtr that WILL GET YOU INTO THE 10 SECOND BRACKET AND PROBABLY THE 9 SECOND TIMEZONE IF YOU CAN DRIVE AND YOUR CAR DOESNT BRAKE.....
BUY THIS SETUP....
$2500 for the manifold and the turbo....... thats as cheap as you will ever find something like this
sorry i forgot to mention that it has a CUSTOM made rear housing..... it is a single entry T04 housing and IS an A/R 1.14.... VERRY QUICK SPOOL FOR A T51R
i am now very much over people telling me that they want to buy this and getting me to send pictures and spending my money calling them only to never hear back again...
like i said earlier i dont want to sound arrogant or rude but if your not GENUINELY interested ie: actually have money and want to buy a turbo setup...... DONT MESSAGE ME!!!!
having said that, i will sell the turbo and manifold for $2000 as a pair this weekend only!!!! if it isnt gone by monday the price will go back to normal and i will just wait till it sells... this offer is only valid for people who have not already contacted me and waisted my time
so come and buy it
  • 3 weeks later...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
