Not really sure if i want to sell my car or not but if i get the right price i will.
im chasing after $17,000. but neg
about the car:
has a full biltz bodykit,
after market bonnet.
full exhuast system.
hks pod.
hks coil overs (absolutely sticks to the road!!!)
done about 163,000km.
manual
clutch is in good nick. doesnt slip etc...
engine is superb not a single thing wrong with it or weird/strange noises.
serviced every 5000km just changed the oil and oil filter on the 6th/12/2010
recently changed the diff and gearbox oil as i like things to run smoothly.
air con is cold
heater is hot etc.
all windows etc are working perfect order.
HID lights with 35watt ballasts
the interior has a full leather retrim looks great!!!!!! ill up load some pics of it soon
head unit clarion about 4 months old. has usb and aux function, great looking head unit
recently installed remote locking in the car.
has a push start button which is pretty cool but when i installed the remote locking in my car i accidently forgot to reconnect the wire for this psuh start button.
can come with the black 17" work rezax wheels (235/45/17) or 18" pdw nova wheels (235/40/18)
and the car will come with a spoiler as i personally didnt like it because i cant see in rear mirror and draws too much attention. i didnt bother gettin rid of those metal pegs that holds the spoiler up as you can see in the pic. spoiler takes 3min to instal if desired.
car will come with a rwc.
car is located in geelong vic.
reason for sale: some cash would be nice and maybe a bigger car.
open to all kinds of swaps. another sports car, 4wd, normal daily car, etc..
car comes with full neons but 2 of them dnt work. 1 side is popped as my mechanic accidently broke them when putting it on the hoist. and the other side i think is a loose wiring (never worked when i first got the car) and there is another neon at bottom of my front bar.... i never used these neons before while driving, not really into neon as it draws too much attention but it came with the car.
thanks for looking.
feel free to contact me.
please note has a very slight dint on rear right hand side.... i tried to take a pic of it at best angle... buti was in a rush .. if more pics needed let me know cheers.
  • 5 weeks later...
  • 6 months later...
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
