Hi
if anyone interested in these plates LV2XL8 meaning Love to accelerate or live to accelerate.
PRICE: $700ono
Price: $500
one plate has scratch on it.
ALSO HAVE APEXI PEN TURBO TIMER for $80, comes with wiring loom.
parts located in Northern Suburbs
Contact me with any question via PM or on 0413 034 521
