Ok its come time for me to grow up an stop wasting money on cars and would like to get something a little newer.
Ive had this car since february this year, i can honestly say ive never had a problem with this car, its reliable as all hell and i drive to nourlunga everyday for tafe so the last 10,000 kms are pretty much highway driving and it gets serviced every 5000ish.
Only problem ive had is i snapped the belt that runs the waterpump, watched the temp go up a little an pulled over an diagnosed it straight away. happened 9 months ago an its never overheated since!
Occasionally has a miss fire but getting that sorted on wednesday when it gets put on the dyno.
1990 M-spec R32
Black
Factory 5 speed manual RB20DET
145xxxkms
Cyclone alarm system
Rego included till Feb 2011
Asking price is $8,500ono Or swaps (preferably cash my way)
Exterior:
Type M kit all round
HID lights
Brake calipers painted with duplicolour (adds atleast 20 Rwkw)
Interior:
Clean as f**k dash no cracks etc
Standard front and rear seats
Standard wheel in average condition
Boost guage in drivers side air con vent
Turbo timer
Custom gear knob
Brand new gear and hand brake boots (not in pic)
Digital climate control
Genuine skyline floor mats
Fire extinguisher in glove box (can never be to careful)
Air conditioning retro fitted and regassed a month ago!
Full Alarm system, remote central locking, knock sensor(very sensitive) Engine start (not currently installed) And all the other anti hi-jacking crap
Stereo:
Kenwood head unit MP3, aux Etc
6x9s in the rear
Front splits with tweeters
Can include 12" Sub (all you need in an amp)
Engine:
Internally standard RB20DET with 145xxxkms, compression test done a couple of months back and got 140 +-5 accross the board
RB25 turbo (OP6) with 5x,xxx kms on it
Rebuilt gearbox, all bearings replaced and 4th gear detents, has a crunch when shifting from 3rd to 4th to quick but its an easy fix!
3inch single piece dump pipe to high flow cat
3.5inch straight through exhaust with nice cannon (not too big) But sounds tuff!
ISC front mount intercooler kit
Extreme heavy duty cushion button clutch (i think)
ISC 52mm twin core radiator
Blitz pod filter
Shoes and suspension:
Stock S14/R33 rims with legal tread for now (this could change)
Drift? wheel nuts (soon to be rays)
Standard suspension, drivers side rear sits a tiny bit lower so may need replacing but doesnt make any noise or make a difference.
Other things you should know:
As i said car currently had a problem, wanted to cut off while driving (suspected fuel pump failure) but hasnt done it in ages but to be safe im getting it tuned and looked at on wednesday by jazmac so might chuck a 040 in there just incase
Starts first time everytime (45+ degree-10 degree days)
Roof is faded, front bar has stone chips, rear passenger side has a bit of a dent so if your picky you would need a respray (i can organise for cheap)
Interior is mint bar the rear side panels (as pictured)
Passed regency no worries 12ish months ago
All new bushes throughout the car
Rear windscreen was dodgey so had it pulled out, had a little bit of surface rust which was removed properly and resealed.
I have tried my best to remember everything but theres probably some things ive missed.
ANY mechanical check is welcomed as long as i dont have to leave my car anywhere (as its my daily) and as long as it doesnt cost me. as i said it will be on the dyno this week so ill see if there are any problems and get a power reading.
Link to pictures here
https://www.sau.com.au/forums/topic/347241-eoi-r32-2-door/
UPDATE: Pulled just under 160kw @9psi today, very healthy engine he couldnt believe it, plenty more in it just needs a little more boost.
$8,000
Edited by slidnreds13
https://www.sau.com.au/forums/topic/347241-eoi-r32-2-door/#findComment-5592123
  • 1 month later...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
