Hey guys
As the topic suggests, im selling my Nismo GT lemans turbos, i made 307RWKW with these untill the airflow meters maxed out. Should see over 350RWKW with correct fuel system
Rated to 640hp as a pair
They have steel wheels so Max boost is around 1.6 bar
Compressor A/R 0.6
Turbine A/R 0.64
360 degree thrust
No chips or damage to the wheels
Had the shaft play checked out at GCG where they said they are still in good condition
Also these turbos are a direct bolt on to standard manifolds.. both oil and coolant lines are a direct screw in
Reason for selling: I have an engine that can handle 500rwkw so goin to go big on the turbo front
Located sydney but will ship
cheers
Edited by GTR_JOEY
https://www.sau.com.au/forums/topic/347639-for-sale-rr581nismo-lemans-turbos/
Hey mate, yea i got the dyno results for it layin around here somewhere
supporting mods were 550cc injectors, full exhuast including 3 inch dumps, apexi air filter intakes and apexi FC
Still using the standard pump
Will also Sell 3 inch dump pipes and bigger front pipes for extra
Goin big single :thumbsup:
Cheers
Cheers
What dump pipes are they?
theres approx 12,000 on them mate,.. im on holidays atm so cant get any pics for another 2-3 weeks
I KNEW I SHOULDA GOT PICS BEFORE I LEFT FOR QLD :angry:
Ill put them up as soon as i can
cheers
  • 3 weeks later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
