I had a thought tonight which is dangerous. :)
I ripped out the wastegate actuator & drilled a couple of 9mm holes next to the origional mounting holes to allow the wastegate actuator to be pulled back and tightened up if you like.
What I'm hoping to do is restrict the full open movement so it helps prevent boost drop in the higher RPM's.
I was able to get in a few fiddles before it went dark tonight.
I'm not using a boost controller.
First tweak showed around 14psi being held up to around 5500rpm where boost dropped by 1psi.
Second tweak bumped boost up to around 16-17psi where up around 5000rpm I hit the fuel cut & heard a little bit of pinging due to boost rising slightly more. Hence the wastegate wasn't able to open enough to control boost.
I tweaked it back a little and moved it too much.
I tweaked again and got it up to around 14.5psi with boost only dropping 1psi over 5500rpm.
Previously it wouldn't matter where I set boost to with a bleeder or EBC in manual mode, it would always drop back to 12-12.5psi over 5500rpm.
Tweak a little more and bring the top end boost up to around 15-16psi.
Its a little bodgy but hey.. its free. :)
Should be interesting to see if it pans out tomorrow. :)
Be carefull playing with this bodgy mod people as I've soon got another motor to play with so i'm not to fussed about damaging this sucker.
I'm trying to get it to hold boost for the next dyno day.
Then compare it to the new motor.
https://www.sau.com.au/forums/topic/34787-my-bodgy-wastegate-actuator-mod/
  • Replies 43
It appears with a bleeder it will only hold roughly 1.5-2psi more than the actuator is rated at.
With a EBC in Auto mode with fuzzy logic it will hold what ever boost thrown at it, my Blitz SBC-iD had no problems holding 15-16psi up top.
Looks like it.. Getting ready for the dyno day.
I fiddled with the actuator on the way home from work this afternoon with excellent results. :D
It took 2 tweaks to get it holding boost up top like I wanted it to.
The final tweak came up on to 15psi pretty hard then in third & fourth slowly creeps to 16psi.
I've tweaked the bleeder a little to bring it straight up on to 16psi and now it holds perfectly flat from 3500rpm (16psi) to 7000rpm. No point reving to 7500rpm.
Defiantely screams up top now. Huge difference in second as previously it would start to die off after 5500rpm and feel like it was just reving, now you can hear the turbo really pshhhhhing :D while you feel that rb20 top end scream.
hey, i also had an in line restrictor boost control, and even bleed control. but i thought the cheapest and best option was that same idea, i drilled a couple of holes and routed in through to the original holes, i am happier with the result, pity i had wasted money on the other boost mods, as this ones cheaper! like no cost!, also i have been playing around with the use of springs onto the wastgate lever, simple way of making the wastgate change its characteristics, just use a heavier spring for more boost.
the only thing i noticed is that if reving 3rd,4th,or 5th when lower in the rev range, the boost will go higher than your optimum gear reving up, but i guess you should always be in the best gear of acceleration if you want to accelerate, even in town driving. just alot more foot control need to be used.
I personally would love an electronicly controlled system, were boost was held perfectly at pre selected levels. but at the price of nudda for the above setup i keeping my money for better value mods.
ps i keep my boost max at 14 but mostly around 12, reliable factor.
Dayna
Dayna,
EBC's arn't all they are cracked up to be. Well mine wasn't as good as I expected it to be. To be honest it was a little dumb and required fiddling with every now and again.
Even when the ebc was in auto mode (dial in the psi you want and it does the rest) & driving up a hill in say fourth gear with lowish rev's boost will climb and spike to 17-18psi where the safety ebc thing would dump the wastegate open. + in auto mode the boost wouldn't hit as hard.
When the EBC was in manual mode which works on a percentage of maximum boost it wouldn't spike up hills etc but it also wouldn't hold boost up top. In manual mode boost would hit nice and hard.
I was going to fiddle with the heavier spring on the welded wastegate but this seems to do the job nicely.
Up hills etc mine doesn't spike high if anything it tends to come up to 1psi under what it runs when at 7000rpm.
RedlineGTR,
Have you tried a RB20DET turbo actuator. They hold 10-11psi standard.
guys
i have also looked into this, although i havent tried it, if you think about it, if you in effect shorten the amount of travel on the actuator the effect will be somewhat like an oxy torch where you have hot gasses comming out of a small(er than usual) hole, in this case the wastegate, and burning the wastegate, which in time would become burn on the edge in the same way metal is cut using an oxy cutting flame.
so be carefull...
but like i said this is all only in theroy, it may be different when put to practice, as most things are
guys
so be carefull...
No it wont burn the little flap. It would melt the exhaust housing too if it was that hot. Even with the actuator in its standard position, the wastegate never really "fully" opens.
Bending the actuator arm is another way of doing it. Just dont break the arm. :D
Have you thought about cutting the end off totally, tapping a thread onto the remaining part, and somehow making a "socket" threaded rod with a mounting hole in it? This would effectively turn it into an adjustable actuator the same as the HKS ones.
I've thought of this in the past and think it would be pretty simple to do - if i could be stuffed
Hmmm, interesting, i might have to try something too!!
I can watch my boost drop from 12psi to 10psi as revs rise, damn i hate that
Since my last dyno run, and I watch it drop from 12psi to 9.5psi as the revs got up high, I've been pondering the same thing.
Any idea what an HKS adjustable actuator costs??
I'm pretty sure it would be the spring tension, it just can't hold the flap closed as exhaust gases increase and speed up :)
I'd be keen to hear from someone that has done the 'R32 actuator on a R33 turbo' mod :D
J
New I think around $150-200. Mine cost $75 second hand. If you see one for under $100, I say grab it. Definitely worth the bucks if you're dropping boost.
wouldn't the boost drop jhust be due to the stock turbo not being able to flow enough at high revs?
That could also be a factory in it too :D But I think at the relativly low boost, I'd say the actuator is the main reason.
Thanks JimX - that's a good price and I'll be keeping an eye out for one.
J
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
