i have this rb25det motor still in car, running so you can test drive it no problem before buying.
i am wanting to get a deposit before i take it out as i want the person who buys it to hear it running.
it has only had a run in tune professionally it made 126kw on 5psi and was shut off at 5000rpm as its just run in tune.
needs another 500km (already done 450) running in then drop oil,oil filter,replace spark plugs then a final tune. easily make over 250kw.easy.
i have receipts for over $4.200 worth of work. internal engine work.
engine has
nismo 550cc injectors. brand new o rings.
garret 25/40 turbo has been rebuilt
microtech computer (no afm)
adjustable cam gears.
asking
engine alone: 4k
engine with turbo, injectors, microtech: 6k
also have a r33 gearbox series 2 with cusco os clutch an cermic fly wheel can include this in a deal.
wanting $2.5k or $1.6k without clutch and flywheel.
only serious buyers please pm me if your really intertested or call me.
everything is still in the car so feel free to test everything out.
prices are negotiable if you put down a deposit.
call me on 0430078630
picture of receipt can be supplied over the comp or can see for real..
price is slightly neg. come and see it running and drive it if you like offer me a reasonable price and we can go from there
Internal mods/what was done:
Dismantle/degrease and inspect long engine
Bore and hone block
Grind cranksharft
Dismantle assemble and align rods
Blance in-line engine assembly
Hone rod bushes
Dismantle/clean/inspect and test oil pump
Remove and refit callery plugs
Recondtion cylinderhead
Assemble to long motor
Brand new engine parts
Forged piston kit (acl race series)
Second hand rods
Assorted gallery plugs and specialty sealants.
All done by Engine Workx in Winchelsea
mate do u want sell clutch seperately??????????????? hws thw condition, and is twin or single plate..?????????
well not at this stage no want to sell the engine first before i start stripping it. thanks for the interest
MASSIVE PRICE DROP ONLY 3K FOR ENGINE ALONE RING ME IF YOU WANT ANY OTHER PARTS ADDED ON AND I CAN ILL MAKE YOU A GOOD DEAL
I'm interested in the whole motor, turbo and computer. Where abouts are you from?
melbourne ring me on 0430078630 and we can talk about it .
    • Hey Nismo, any chance in the world you still have these seats?
    • I'd say closer to OG GTX3582R, just smaller trim - so 59mm inducer/82mm exducer as opposed to 62/82 for the first gen GTX3582R. Yeah EFRs were boss, the EFR8474 is still an absolute beast and it perplexes me that people still go to things like Turbosmart/Garrett etc when the results people are getting with those are pretty unremarkable compared to what you could get with a turbo available well before those options came out.  DriftSquid (I think) "upgraded" from an EFR9174 to a Turbosmart turbo and promised a comparison video - and kinda shuffled awkwardly and did a bit of diversion from the fact that they didn't get any improvement going to the currently massively hyped brand of turbo from a turbo that was a bit of a frankenstein that had been well superceded in it's own range before the Turbosmart unit he put on there even came out. I suspect the EFR would outperform most Xonas for what a lot of less-insane RB owners would go for, in the 400-600kw range but the Xonas are looking hard to beat up to maybe in the mid 700kw range at this stage- basically where EFRs don't really reach, and before the Precision turbos take over.  What the Xonas do well in the "EFR range" is be easier to package etc, and work very well if a divided housing doesn't suit your application.
    • Are you sure the gasket is blown? What are the issues? Thermocure is the only flush I've seen do anything with rust, very impressed with that, Prestone, rust will be by the pool having a cigarette.
    • And since the flush you have a blown head gasket? Have you lifted the head off yet?
    • The answer is to get a hold of the wiring diagram, work out what voltage is supposed to be where, when, and then work out why it is not there, then. I can't speak to the HR34 stuff, because I have never paid any attention to the NAs. There is a possibility that the turbo diagram will help, but it could also be different - depending on whether there is an FPCM on the NAs.
