Hey guys.
I'm still after a 3.5" cat-back exhaust. Would preferably like to hear it running on a GTR (video or whatever) as I'm a bit picky about how it sounds ;)
Please let me know what you have.
Cheers!
https://www.sau.com.au/forums/topic/348107-wanted-cat-back-exhaust/
  • 4 weeks later...
  • 3 weeks later...
  • 2 months later...
