Hi guys i have a Varex exhaust on my car, the valve that opens and closes was working when i bought the car but now it has stopped working for about 5 months. It wasn't bothering me but now i got an EPA notice so i need to close the damn valve and it wont work i have 2 remotes the valve motor wont respond to either of them i figure its an electrical issue.
Just wondering if anyone's kind enough to lend a hand and help me try and fix my exhaust iv had a fiddle around with the wiring to see if anythings loose but it seems to be all fine! i just need to clear my EPA wondering if anyone has a spare stock R33 GTST exhausts lying around? i just need the tip/cannon part to borrow it.
Willing to pay for the help if necessary or a slab of beer : )
Cheers and Merry Christmas!
https://www.sau.com.au/forums/topic/348139-varex-exhaust-valve-stopped-working/
There's a bit of info on fixing the varex valve mechanism or i believe you can even order some parts from x-force to fix it as some people have suffered it.
A quick google search should turn up some results.
GL
Ps. I think EPA will pickup on the varex, you'll need to find a stock exhaust and make sure your cat is in healthy working condition before heading to the check.
My cat back is healthy was at the mechanics not to long ago the whole system is in good condition no holes etc.. ill do a search around to try and fix the issue. I still need a stock exhaust : / anyone kind enough to lend me there's?
  • 4 weeks later...
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
