For sale is an Apexi AFC Neo, ive had it in the car for about 6 months and has served its purpose flawlessly.
Every thing is operational on it. Have already taken it out of the car and it is ready for postage.
Only thing that you might consider wrong with it is that ive glued some velcro to the back of it as the glue that came with the velcro melted in heat.
Did a kinda fail job with it but you cant see it anyway.
Price: 300+postage
Feel free to pm me any questions.
https://www.sau.com.au/forums/topic/348212-for-sale-apexi-afc-neo/
You need a wideband sensor to properly tune the a/f ratios. I handed it over to a tuner and they did their thing, only took 1 hours worth of tuning time, that was on an N/A car though.
Using them is very easy its just 4 directional buttons and an enter and back button to navigate through the options.
This is a pretty informative site to look at: http://www.axidworks.com/Apexi%20S-AFC%20NEO
