i have 2 x 2011 bdo tickets that i may have to give up due to work. Asking what i paid for them $334.60.... will ship for free. Pm me if your interested.
Edited by joshm35
https://www.sau.com.au/forums/topic/348334-fs-2-x-2011-goldcoast-bdo-tickets/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
