Getting rid of these gauges as i got some new digital ones for xmas..
boost gauge (bar)
Water temp
Oil temp
Oil pressure
All gauges are fully functional and look great
They all come with brackets, neccesary lines from gauge to engine bay, oil&water temp sensors included, i also have a t-splice if needed too
Havent got any pics atm il upload some tomorow tho if anyone wnts pic before then i can MMS pics.
After $180 for everything, can split up if needed too would prefer to go as a package tho
Cantact- Simon: 0402547310
https://www.sau.com.au/forums/topic/348551-omoni-gauges-x4/
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
