As above. I have an R33 s2 drivers seat i was going to make an office chair out of. I now dont have the space so im going to offload it.
It has some tears around the drivers side bolster so thats why its only $50. Not sure if it can be repaired or not. Could always put a seatcover over it or use it in a drift car or something. i only changed it so i could sell my car for more.
If anybody wants photos let me know and il take some.
  • Like 1
https://www.sau.com.au/forums/topic/349019-r33-s2-drivers-seat-with-rails/
  • 3 weeks later...
