hi boys and girls,
selling my belovid 34 4 door as i want a change!
mods are
-perl white
-sunroof ( all working no leaks)
-factory fog lights and HID's
-factory skirts and rear pods
-origin silver carbon fibre boot lip
paint is IMMACULATE, looks like a new car.
- Cusco Zero 2 R coilovers ( 5,000 kms old)
-strut brace
-work VS-XX wheels 18x9 and 18x10 +26 all round New federal tires
- apexi power intake kit
- 3" turbo back exhaust with twin pipes
- drift oil catch tank ( doesnt breath a bit)
- Apexi SAFC with road tune ( 200+ rwkw)
-Rb20 turbo actuator ( set on 12 psi)
- tiptronic auto ( shifts well)
- boost guage
- big stereo with bluetooth, i pod ect, 2 amps proffesionally mounted in the boot, splits all round, pioneer sub ect.
the car has done 126,000 kms and has recently had the water pump and timing belt replaced, along with a freshen up of the trans,
Car is located in SA but has NSW rego atm, can change to sa for the right buyer.
Gets heaps of looks, this has also been fitted with a " pussy magnet" .. hehe
Interested in swaps as well .
$16k. - you wont find 1 like this!
https://www.sau.com.au/forums/topic/349126-r34-4-dore-fairly-damn-jdm/
  • 4 weeks later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
