Hey Guys,
Excuse my stupidity in asking this but your help would be appreciated.
Ive been trying to upload my avatar with no luck, I presume that your supposed to go to user cp then edit avatar and then load it up from your pc. All that is ok but when I click on save changes it takes me to current photos gallery or somethin and when I post it doesnt come up :confused:
Thanks for the help,
Terry
https://www.sau.com.au/forums/topic/34980-avatar/
