1994 S14 S1
Rego till 27.04.2011
Travelled just over 160,000km. Of which I have only done about 10,000.
Compression tested before purchase, came up at 140psi +/- 2psi
Serviced every 5,000km with Fuchs Titan SyperSyn 5w-40
Gearbox oil has been replaced with Redline Super Lightweight Shockproof gearbox oil
At 155,000km taken to Dr Drift where he tuned and installed:
Nistune,
Gktech rocker arm stoppers,
brand new Z32 AFM,
Turbotech boost controller, and
3A Racing air filter.
With 100ron petrol (United 10% ethanol mix) she reeled off 161.4rwkw, maxing out the injectors because of the ethanol blended petrol. With bigger injectors will make 180-200rwkw easy.
Other modifications include;
HKS Hyper D coilovers,
APS Front mount (no holes),
Walbro GSS-341 in tank fuel pump, installed about 1000km before tune,
Relay directly wired to fuel pump,
Relay directly wired to coil packs,
HEL Braided brake lines F+R,
Slotted RDA front and rear rotors, not even 1000km old,
EBC Green Stuff front and rear pads, not even 1000km old,
Rear Whiteline 22mm adjustable swaybar with new front swaybar links,
Autometer 2 1/6" Boost gauge on steering column,
Brand new wheel studs on all 4 corners,
Unknown brand 3" turbo back into a Magnaflow rear muffler.
Parts I'm willing to sell at extra:
Powered by Max subframe risers,
Superpro front swaybar D bushes,
Brand new front tie rod ends,
Brand new front swaybar links (Mitsubishi GTO, will explain to the purchaser how to put on),
Superpro polyurethane steering rack bushes,
and finally a set of GKTech Tie rod end lock spacers.
Also have a brand new externally gated turbo from APS, it is a Mitsubishi/Trust turbo, slightly bigger than a T28, but externally gated.
No rust, no damage.
Comes rolling on freshly painted 32 gtst rims, and a spare set of S14/R33 gtst rims.
Asking price, with all above parts, $11,000.
Just the car, $9,500.
Will consider swaps for a cheap slider, S13 or the such (possibly track only), plus cash my way, or a daily + cash, must be manual.
PM me if interested.
https://www.sau.com.au/forums/topic/350002-zenki-s14/
  • 1 month later...
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
