ENKEI 17x8 RIMS not sure of the offset they are on my r32 gtst with no spacers NEXEN tyres with 65-70% tread all round
i just bought some stock rims so these have to go cause i need the money $470ono
JASMA MUFFLER hangers welded for any R32 it is 3.5 inches have the power without the noise has slight crack but can be fixed easily $100 ono
pickup from ermington in sydney
$50 for the muffler
this things sitting on the living room floor and if it sits there much longer i'm going to end up in the dog house
  • 2 months later...
I finally picked up and fitted the stock wheels to my R32 so I have the Enkei's sitting around ready to go $380 no offer over $350 will be refused
Just to clarify they are 5 stud 17x8 with 35 offset call or text me on 0466893693
I need the cash quick these are on eBay currently bid at $250 with 14 watchers. First to offer me $300 and can take them before the auction ends on Wednesday can have them
pm me ur mobile number and ill see what i can do..regarding about the enkei's
if you can do that plz
cheers
Edited by GGGTS4
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
