Z32 Afm, Greddy Y Pipe, R32Gtr Coil Packs, Apexi Afc Neo Piggy Back, Wolf V500 Wiring Harness For R32Gtr Blitz Blow Off Valve Rb26 Block Crank Rods Fs
hey guys got a few things for sale that i no longer need due to up grading computer
2 x Z32 Afm with plugs perfect working order one of them i lost the plastic top plate still works fine just has a black plastic plate silconed on there $150 each
set of 6 r32gtr coil pasck used for fault finding turns outs wasnt my coil packs work fine $80
an apexi afc neo piggy back computer still on car will take off when someone buys works perfectly $300
greddy y intake pipe used for twin afm on a single turbo $300
wolf v500 plug and play wiring harness suit r32gtr might suit r33gtr aswell unsure tho $300
also have a custom made y pipe to suit single turbo with 2 afm $100
blitz blow off valve $60
also have an rb26 block crank pistons rods spun a bearing so if anyone interested in anything like that msg me
if ur interested pm or msg me on 0437138320 can provide pictures more if needed cheers
will post at buyers expense
Edited by t04z
Hey man power fc still there. If full set up including handset still available for 300 ill take it for sure . Text or call 0433490972 . bris
LOL, would have been gone before he put the ad up if it was, read it again.
Jack - re R32 GTR Coil Packs x 6 for $60.
I'll take them. They are GTR, not GTS-t, right?
Pls let me know postage to Melbourne and I'll credit you the cash.
E-Mail me your bank details and cost here: [email protected]
Rgds ...
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
