  • Replies 99
How aboutttt... 14th April? Nick should be back, my car should be back... as should a few others and lots of notice so we can squeeze more cars in! :)
everyone happy?
yeh if you make it around that time my car will be ready also.. a thursday Cassie?
g35me: What date were you thinking of in Feb? I can always run multiple nights, if there's enough interest per night.
The other option is to do a private shoot. Costs a bit more, but more photos and more time spent on your car. Works out cheaper in the end fo the amount of photos you get. Plus you could dictate what location :)
Edited by tangcla
A private shoot is $150. You get around 15 photos, at full resolution (i.e. ~5600 pixels at its longest side) which is large enough to print to larger than A0 size (i.e. 4x4 A4 page grid).
Don't know why it needs to be so far away :P or is this all about you?
Excuse me while I go get some popcorn :D
but seriously guys - if there's enough interest earlier or later, we can just run a second night :)
