Hey guys,
Wanted to see what people had lying around in the garage and are willing to get rid of. I'm trying to re-roadworthy and tidy up a track car I recently bought. Please let me know if you have and bits I'm after, condition and a price.
I'm after:
rear washer jet
rear wiper motor
washer bottle with both pumps
boot lock clip
floor carpet
centre/wing brake light (with wiring intact)
horn
rear view mirror cover
p/s window seal from door card (if anyones got one fallen off or an old door card)
airbox and snorkel
a/c compressor, condensor and lines
A pillar trims (p/s and d/s)
Thanks for any help
https://www.sau.com.au/forums/topic/350292-wanted-r33-s2-gtst-bits-and-pieces/
hey man, i might be able to help out with the rear view mirror and horn. There yours for $10. Both are in good condition. I've attached a picture of both items so you can just confirm that this is what your after. I only have one of the horns though as I think there are 2? don't quote me on that though.post-52764-0-08674900-1295153360_thumb.jpgpost-52764-0-10025500-1295153416_thumb.jpg
  • 4 weeks later...
hey tyrone thanks, I have already picked up those 2 parts, thanks anyway.
Anyone.
still looking for:
floor carpet
high stop light from S2 spoiler
A/C compressor, condensor and lines
hey bud i have an r33 s2 and i have the carpet in mine and im sure i could get alot of the parts you need as i have another one at work i have totaled
i have a rear wing with the led stop light in it and its a gtr wing and i also have these parts avalible if you would like to call me on 0415725472
standard wing
and alot of small bits and peices but i can also check the car tomorrow when im at work and see what else is there just im in townsville
  • 1 month later...
Hey guys update on parts i'm after.
high stop light from s2 spoiler
or alternatively a duck wing spoiler.
p/s door card, condition doesn't matter, i only want the window seal off it.
oil cooler and oiler filter relocator.
nismo gear knob
shift pattern placard
thanks
ben
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
