yesterday my mate took my car for a spin and about halfway through the drive i noticed the car was having a problem down low. Once i got home the car was hunting at idle. I than disconnected the battery for the night and also tested the coils this morning and pulled out my plugs which were very carboned up. I than cleaned the plugs and also did a compression test with ok results and than put it all back together.
I than started the car with no difference whats so ever. I also replaced my z32 afm and recaled my emu to standard. I should note i cleaned out my aat valve about 2 weeks ago and was running fine. I than started the car and noticed idle was slightly better but not by much at all. I than took it for a drive were the car seemed to have issues going over 2000rpm. i than got it home and put some octane boost clean in the vehicle as we have had alot of water around and there has been rumours about water getting into fuel. I than let the car idle for about 30 minutes and found that the car became more responsive untill i went to go for a drive and found it would not accelerate at all. I managed to get it home and left the car sit for about an hour Now it wont even start it will fire up but than die. Any help for be very grateful.Thanks
https://www.sau.com.au/forums/topic/350546-help/
I reinstalled the z32 afm and the car is running again but still very rough. It also seems to chewing the fuel as well i have a done a vac test around the engine bay and it doesnot affect it at all. I really hoping it something easy but im dreading it the engine
https://www.sau.com.au/forums/topic/350546-help/#findComment-5627237
you only just put a bigger turbo, etc on didn't you? have you had a tune done yet? if not then it is probably running rich as anything and fouling up the plugs, and since you are running an emanage the ecu is probably still seeing excess airflow and backing the timing right off.
have you changed the injectors at all (or even just had them out)? may be that one isn't seated properly. could also possibly be a vaccum leak.
https://www.sau.com.au/forums/topic/350546-help/#findComment-5628594
hi i just replaced the afm and cleaned spark plugs with some cleaner and my bbq car than started did hunt a little but followed acc cable to throttle body were it was lose i also noticed the spring didnt go all the way back so i adjusted it best i could seems to be running alot better i think plugs fouled up and just got worse and worse till they wouyldnt run anymore well hoping anyways i have not taken it for a drive yet asi had a beer while working on it so im not going to risk driving also most roads have been blocked off so no tune yet but atleast they open now
https://www.sau.com.au/forums/topic/350546-help/#findComment-5628735
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
