So heres my problem,
got a S2 RB25DET to put in the R32gtst of mine, using the R32 loom and microtech LTX16S ECU. Then I realised that the coils on the S2 are different as they have the igniter on the coils where as the S1 are the same as the 20 coils...If I cant swap the coils over is there any way to get around it without using the 25 loom?
Thanks
Just use the RB20 coils otherwise you will need to rewire the connection of the RB20 loom to the RB25 coil pack loom. I have attached a photo of an RB25 S1 loom I rewired to suit R34 coil packs (with built in transistor in the coil pack). Unfortunately you cant see the connector but it is a single 8 pin black plug.
RB20 coils are rooted, got brand new splitfires for the 25. so I can just splice the rb25coil pack loom to the rb20 loom and it should be good?
thanks heaps
thanks heaps
Modify the RB20 loom with the addition of the mating 8pin plug to suit the Rb25 coil pack loom. You will need to remove the RB20 transistor plug and 3pin (power,earth and check connector) plug and join them to the respective pins on the 8pin RB25 plug (you will need to source this plug). The wiring diagrams will help.
  • 4 months later...
In addition to this, I am currently doing the exact same conversion, aside the coilpack issue as I have my complete rb20 still avaialble for parts is there anything else that would need to be replaced so the rb20 loom and ecu could be used with the Series 2 RB25..???
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
