gobiz Posted January 21, 2011 Share Posted January 21, 2011 Hi, sorry for noobish question but have done a little search but no conclusive answer. My block is being bored at the moment to fit 86.5mm forgies. I've looked around and available headgaskets seem to be 87mm and 88mm. Which size do I choose? Thanks Link to comment https://www.sau.com.au/forums/topic/351204-headgasket-to-fit-865mm-bore/ Share on other sites More sharing options...
Tangles Posted January 21, 2011 Share Posted January 21, 2011 get the 87mm mate cometic street pro is a good kit, can get the whole top-engine gasket kit for under $300 delivered, ebay includes Multi layered steel head gasket Im using 1mm oversize head gasket on both my Rb25 and Rb26 engines, stock bores Link to comment https://www.sau.com.au/forums/topic/351204-headgasket-to-fit-865mm-bore/#findComment-5635743 Share on other sites More sharing options...
Amoreuxi Posted January 21, 2011 Share Posted January 21, 2011 (edited) Do consider the permaseal MLS gasket. As good as the cometics. They also do inlet etc gaskets for the rb's.. The inlets look a little better than the factory stuff but factory is better on the exhaust side. The few times I've replaced my inlet gasket (just removing head playing with restrictors etc) i've found the factory inlet gasket appears the be leaking 'slightly', the permseal doesn't appear to have, its a little chunkier on the metal embossed seal. I've never machined the inlet/head face so it may simply be that but the permaseal inlet gasket definitely sorted the very very slight seep i had. The Permaseal MLS i grabbed from motor traders for a little over 200. the inlet/exh gaskets etc was dirt cheap. $100ish all up from memory. Edited January 21, 2011 by Amoreuxi Link to comment https://www.sau.com.au/forums/topic/351204-headgasket-to-fit-865mm-bore/#findComment-5636441 Share on other sites More sharing options...
Duncan Posted January 22, 2011 Share Posted January 22, 2011 I've just used a permaseal one, and have used cometic in the past. no sign of trouble with either Link to comment https://www.sau.com.au/forums/topic/351204-headgasket-to-fit-865mm-bore/#findComment-5637400 Share on other sites More sharing options...
Char Posted January 25, 2011 Share Posted January 25, 2011 (edited) mine is 86.5mm cant remember what thickness the head gasket was atm, think it was cometic metal headgasket mulit layer VL Turbo one got compression of 160 on all 6 --pistons are 8.5:1 can ask my tuner if u need Edited January 25, 2011 by Char Link to comment https://www.sau.com.au/forums/topic/351204-headgasket-to-fit-865mm-bore/#findComment-5641452 Share on other sites More sharing options...
mattis96 Posted February 4, 2011 Share Posted February 4, 2011 can someone please tell me asap if you can you use the rb25 head gasket with no dramas on the rb30 block, have searched but no definite answers i could find, thanks Link to comment https://www.sau.com.au/forums/topic/351204-headgasket-to-fit-865mm-bore/#findComment-5656503 Share on other sites More sharing options...
Char Posted February 6, 2011 Share Posted February 6, 2011 no you cant Link to comment https://www.sau.com.au/forums/topic/351204-headgasket-to-fit-865mm-bore/#findComment-5658352 Share on other sites More sharing options...
JonnoHR31 Posted February 7, 2011 Share Posted February 7, 2011 can someone please tell me asap if you can you use the rb25 head gasket with no dramas on the rb30 block, have searched but no definite answers i could find, thanks need rb26 or rb30 gasket Link to comment https://www.sau.com.au/forums/topic/351204-headgasket-to-fit-865mm-bore/#findComment-5659454 Share on other sites More sharing options...
