G'day Peter.
Since the demise of the Asuka tuners (hard to get in small quantities at an affordable price), I've been hunting for a suitable replacement.
I've tested a few which were OK but had their limitations. This last one looks the goods in its anodised aluminium case and works really well. I sent one of my 2 samples to Brad (Ducati02) in SA and he did a back-to-back comparison with the Asuka HR3 and found the new tuner picked up signal better and in places the other didn't.
Based on my testing and Brad's recent feedback, I've placed an order for a small quantity. These units have been upgraded to come with a an AV input including cable (not shown in pic) that can be used for reverse cam (it switches to that input on supply of 12V to a wire) or any other AV source like DVD/GPS etc. Because of the special order they are not sitting in a warehouse ready to ship and with Chinese New Year happening soon, the delivery date could be mid Feb.
There is one in SA if you are desparate to have it straight away. The other is in my Stagea & I'd rather keep it :)
Oh, and the price looks like it will be ~$230, plus maybe $15 in postage. This makes it excellent value when you consider it comes with antennas and the RCA leads where the Asuka didn't.
Cheers, Leon.
https://www.sau.com.au/forums/topic/351465-v35-tv-tuner/#findComment-5640411
Yeah, they're close. Manufacturer is putting them together on Monday and shipping soon after. They say they'll be here by the end of next week, but I think it'll be a few days after that. I've asked for an extended IR remote sensor cable (5m long instead of 3m on samples) and they will supply these with this batch.
I'll post some more pics and install options in a new thread soon. Cheers, Leon.
https://www.sau.com.au/forums/topic/351465-v35-tv-tuner/#findComment-5667600
  • 3 weeks later...
Hi everyone. The tuners are here and I've assembled a few extras to help with the installation.
I've posted the details on the Stagea forum since that's where most of the TV talk seemed to be.
http://www.skylinesaustralia.com/forums/topic/356219-tv-tuners-once-again-the-new-asuka/
I look forward to hearing from you. I'll PM those who expressed prior interest later.
Cheers, Leon.
https://www.sau.com.au/forums/topic/351465-v35-tv-tuner/#findComment-5700920
The thread (link above) is now updated with some very basic info to help everyone with the DIY. More detail to come in the next few days.
Please feel free to ask questions there or continue to PM me for more info and/or help.
https://www.sau.com.au/forums/topic/351465-v35-tv-tuner/#findComment-5712155
Interesting... where do you mount the antennas?
I may get one if the reception feedback is good.
Hi Tim, I've been told the best place for the antennas are front & back screens for maximum separation. Coax runs behind A pillar & C pillar trim & the antannas stick to the glass right at the top. I saw pics from one install and they couldn't be seen from outside, but he also had a strip of dark tint at the top.
Reception in capital cities is normally pretty good with these antennas. They are almost as good as the factory ones in the Stageas which we are lucky enough to be able to use.
https://www.sau.com.au/forums/topic/351465-v35-tv-tuner/#findComment-5715279
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
