selling my r32 gtr, wanting something different now. not perfect needs a bit of tlc but has a lot of potential. asking $10,000
MODS:
APEXI PFC
TORQUE SPLIT CONTROLLER
VAREX REMOTE VARIABLE EXHAUST
HKS PILLAR MOUNTED BOOST GUAGE
AFTERMARKET COILOVERS
ADJUSTABLE FRONT CAMBER AND CASTOR ARMS
CLIFFORD ALARM SYSTEM
HID UPGRADED HEADLIGHTS
BAD POINTS:
NO REAR SEAT BELTS
MISSING REAR QUARTER WINDOW SURROUNDS
MISSING BOOT TRIM
REAR RIMS HAVE A FAIR BIT OF GUTTER RASH ALSO A SMALL CRACK IN 1 AND A DENT IN THE OTHER
FRONT RIGHT OUTER CV BOOT TORN
BROKEN LHS REVERSE LENSE(LIGHT WORKS)
its listed on ebay so theres some more pics of it there which were taken on my old phone, or just ask and i can add more here
selling her as is without rego or roady. located in enoggera just north of brisbane city
ph:0435169047
https://www.sau.com.au/forums/topic/351833-1992-r32-gtr/
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
