1) Jap cat-back system. 2.5" good condition, jasma approved. . . two muffler and nice round tip with slight splice back, good for defects $150
2) standard clutch fan $20.
3) Silver top Injectors RB20det x6 . $120
4) Standard R32 GTST Computer $80
5) Moulded mud guards. $50
6) GTST Spoiler in sky blue, with brake light? $40
7) Turbo LSD - 5 Bolt - $150 without half shafts
8) Bonnet cable set-up, with latch and interior puller. $20
9) 3" one piece dump pipe $120
10) standard t3 turbo, has shaft play. $100
Prefer Local Pickup. can post small items...
Im need a 32 headlight, so if you have one then let me know!
Please call or pm
0411 117 167
located in Mill Park
Cheers, Anth.
https://www.sau.com.au/forums/topic/352786-r32-aftermarket-and-stock-parts/
Price drop
2) SOLD
3) Silver top Injectors RB20det x6 . $100
4) Standard R32 GTST Computer $70
5) Moulded mud guards. $40
9) 3" one piece dump pipe $110
10) standard t3 turbo, has shaft play. $80
  • 1 month later...
  • 1 month later...
Anth,
I have a set of R32 headlights.
Am in Melbourne - If you are still interested, best you come and look to make sure that it's what you want.
Les . . .
____________
Please call or pm
0411 117 167
Cheers, Anth.
sorry guys havnt checked this in ages! diff is from a turbo manual, R200 i believe?? 3.9 gearing. . . i have a auto non turbo one atm which is 4.36 ratio in the car. . . good for skids haha but im keeping that one
  • 4 weeks later...
UPDATE!!
1) Jap cat-back system. 2.5" good condition, jasma approved. . . two muffler and nice round tip with slight splice back, good for defects $150 quick sale!!
2) rb20det crank angle sensor $140
8) 3" one piece dump pipe $110
9) standard t3 turbo, has shaft play. $80
Cheers
  • 3 weeks later...
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
