selling a garrett 35/40 was goin to put it on my nissan patrol but need the cash, had it looked over and was toled its perfect, its had the larged flapper put on it previous owner said it was boosting to 15 without a boost controller.
asking $850ono
mobile 0422412194
sorry guys will put pics up tomorrow
https://www.sau.com.au/forums/topic/353183-garrett-3540-need-it-gone/
