you really dont need a reg unless you run into other tuning issues.
dont get a malpassi, they work grate but after a month or so they start making a horible noise every time you prime the pump. ive seen this happe quite a few times.
turbo smart ones are ment to be grate and are resomly priced.
Sard ones work well but i know of one person having problems with his.
i getting all the bolt on mods i can get befor i have to rebuild my engine ..
Welcome to category 4:
http://www.skylinesaustralia.com/forums/topic/347759-installing-a-fuel-pressure-regulator/page__pid__5601024#entry5601024
The only reason to "upgrade" the factory FPR is really in three instances:
1. When your injectors are starting to max out, but you don't want to upgrade them, so you bump up the rail pressure with the aftermarket adjustable fuel pressure regulator to push them a little but furthur. Obviously this isn't ideal and most people don't recommend it. Just buy the correct injectors to start with.
2. When you are running huge amounts of boost and the factory fuel pressure regulator can not keep up the 1:1 fuel pressure ratio. Therefore you will need an aftermarket fuel pressure regulator that can handle this high amount of boost pressure and keep up the 1:1 ratio.
3. The factory fuel pressure regulator has failed so you may choose to buy an aftermarket one however still run it at factory fuel pressure.
So as you can see, not many people fall into the second category because a lot of people don't run 2+bar of boost through their car. A few do fall into the first category because they may be on a budget and don't want to upgrade the stock injectors so they choose to bump the rail pressure up instead and obviously a few will fall into the third category.
However there is a fourth category that you will find 90% of people with aftermarket fuel pressure regulators fall into:
4. They have no idea what an adjustable fuel pressure regulator does, but they got told to buy one by a mate or read about one somewhere.
For your situation assuming that you are not running E85, your 700cc injectors should be fine for between 400-500HP therefore you do not need an aftermarket fuel pressure regulator.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
