Dunno if I'm allowed to post this sorta stuff but I was extremely close to buying this car, flights booked to Perth and all, but then something told me to get this car checked out...
Made the owner take it to a mechanic who then told me it was f**ked.
98psi on #1 cylinder and 180psi across the rest. Brakes were metal on metal and motor was knocking...
This was probably 4 months ago now and he hasn't removed the listing or adjusted price. I'm curious as to wether he knew before hand and just wasn't going to mention it to me or not.
Just hope the people out there are doing there homework before they buy cars.
Even the caryards are dodgey as hell. My advice if it's a fresh import: run the vin number through every search engine you can find. I found mine and the info varied between dealer and the advert I found.
TRUST NOBODY and remember; you are doing them the favour by buying the car, not them doing the favour by selling it to you.
And most importantly get the car looked over (compression and leak down test is a must)
If I'm not allowed to post the link below please delete mods
but I'll leave this description:
pearl white 260RS in Perth, dayz options, 34GTR wheels, un-necessary fuel and intake mods...
Good luck and thanks for listening to my rant ;)
http://www.carsales.com.au/used-cars/private/NISSAN/STAGEA/details.aspx?__Ns=pCar_PrivateSpecialFlag_Int32%7c1%7c%7cpCar_ImageCount_Int32%7c1%7c%7cpCar_LastModifiedDate_DateTime%7c1&__Nne=20&R=8854702&Cr=4&model_id=4606&__N=4294960181%204294963846%201216%20834%20285%20257&silo=1003&seot=1&make_id=5&__No=60&trecs=74&__sid=128FD21CE450
Edited by Brendan260RS
https://www.sau.com.au/forums/topic/353455-dodgey-dealers/
i don't think i'd even get as far as a comp/leak down test....things like 'gearbox sticking in third (because i thrashed the synchros), just needs oil (and a rebuild) but i can't get the drain plug off (because i rounded it off trying to open it with a sledgehammer).'
or
'rear shock needs replacing (including all other rear suspension components, cradle, and HICAS most likely shot to pieces) after damage with a gutter (which i fully sik'd into).'
https://www.sau.com.au/forums/topic/353455-dodgey-dealers/#findComment-5665598
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
