A few r32 and other parts for sale.
Exedy HD Button Clutch Kit. Fits Nissan Skyline R31 / R32 / R33 / R34. Brand new in box/packaging. Never used. - $550ono
GAB Sport Coilovers / Height Adjustable - Fits r32/s13. - No knocks or leaks, just a bit dirty - $650ono
NISMO JTC LightWeight Rims - PCD: 114.3 / 2x 16x8.0JJ OFFSET: +38 / 2x 16x7.0JJ OFFSET: +30 - Still plenty of tread on them - $700ono
Just Japs Stealth Front Mount Intercooler(black) - $200 - Brand new, still in box.
r32 Stock turbo - $80ono - Upgraded to t3/t4 turbo, no need for this now.
GKTECH De-cat Pipe - $70firm - Brand new, still in box. Fits r32/s13/180sx/s14/s15.
Mines ECU for RB20DET - $120ono
TUNE:
Fuel mapping has been changed
Ignition timing adjusted
Speed limiter has been cut
Rev limiter has been raised +500 rpms
Settings are for the bare type air filter (mushroom type),
and tuned according with a HKS Turbo T3G turbin kit.
r32 Stock springs - $20ono - Came in the boot of car when i purchased it.
r32 Front+Dump Pipe - $20ono - Upgraded to 3" turbo back. Has surface rust, but no holes.
r32 Stock Lower Control Arms - $50ono - Upgraded to r33 LCA's so these are laying around. Still straight, but one of the bushes isn't the greatest.
Just Jap Hicas bypass Kit - $30 - Brand new, still in packaging.
r32 Type-S? Front bar - $20ono - Sprayed in satin black.
r32 SMIC - $50ono
r33 Climate Control Unit - $15ono
PM me if interested. Will Ship interstate. Located in Melbourne, postcode 3021.
Frontbar + LCA's SOLD pending payment.
PRICEDROP:
GAB Sport Coilovers / Height + Damper Adjustable - Fits r32 & 180sx/s13(rear). - No knocks or leaks, just a bit dirty - $500firm
NISMO JTC LightWeight Rims - PCD: 114.3 / 2x 16x8.0JJ OFFSET: +38 / 2x 16x7.0JJ OFFSET: +30 - Still plenty of tread on them - $600ono
Just Japs Stealth Front Mount Intercooler(black) - Brand new, still in box. $180firm
r32 Stock turbo - $70ono - Upgraded to t3/t4 turbo, no need for this now.
r32 Stock springs - $10ono - Came in the boot of car when i purchased it.
r32 Front+Dump Pipe - $10ono - Upgraded to 3" turbo back. Has surface rust, but no holes.
Just Jap Hicas bypass Kit - $20firm - Brand new, still in packaging.
r32 SMIC - $40ono
r33 Climate Control Unit - $10ono
  • 3 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
