Just wondering if anybody can tell me the difference between an Autech rb20det from an Autech A31 Cefiro & other rb20's? I've just found one for sale & after googling for a while the only difference I can see is that it has a "tuned by Autech" badge on the plenum where as others have "eccs".
https://www.sau.com.au/forums/topic/354288-autech-a31-specs/
They're tuned differently and have a different turbo.
They may have other bolt on differences, like different side mount intercooler?
Buy a sales brochure off YahooJapan, that'd have all the info in there - they're written in Japanese but most information like power outputs and shit is written in English.
Not even the motor.
Turbo and ECU is where it's at.
Other Autech stuff
Body kit (obviously) (plastic, not fibreglass)
Interior (cream leather all round, black stripe up the middle/arm rest on the rear seats)
Wheels
Automatic transmission
Exhaust is different, not sure how.
Not even the motor.
Other Autech stuff
Wheels
Should have explained myself better, I'm after a complete motor inc. turbo, electrics, etc but as I've alreadY got a nistune & 5spd I didn't want the ecu & auto.
Already have Autech skirts & rear, just trying to find a front bar.
Interior would be nice, do you have any pics of what it looks like?
As for wheels, auto & exhaust, pass.
If anyone is interested HERE IS THE LINK.
Aaah k, the Autech improvements over the standard Nissan Cefiro is pretty minimal - better off to just modify any old RB20 yourself and get a tune.
The only physical difference is the turbo and/or actuator.
http://www.importconcern.ca/stock/100080/
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
