hey guys just clearing out my parts so make offers, some prices are firm others are open to offers cheers
Bride seat driver side in good condition a bit of wear onthe right hand side otherwise seat is mint $650 no rail now $550
Bride passenger seat comes missing the seatbelt holder andrecliner, otherwise seat is in perfect condition no tear just a little wearshows on picture $550 now $450
Lock nuts for nissan thread, brand new, never used still inpackage $30
greddy turbo timer, top of the range one with instructionbook and all functions, comes with loom, full auto turbo timer, has many otherfunctions, was on the car for 2 days then removed, comes with instructionmanual $150 MAKE AN OFFER now $100
R32 strut brace for the front, $120 OR MAKE AN OFFER WANT ITGONE now $100
R32 2 door rear boot with type m spoiler, stil has nissanlogo sticker on it, comes with lock and brake light $80 ono now $50
R32 TYPE M cluster, all mounting brackets in tact, perfectcondition, done 174 000 $120 ono now $100
R32 cluster surround auto matic, bvery good condition comes with all switches etc etc $70 ononow $50
R32 cluster surro8und manual, comes with all buttons in verygood condition $120 ono now $100
Hollowed out r32 cat $30, cheap way of de catting!
located in vic, western northern suburbs of melbourne
pm or call 0413 926 794
  • 2 months later...
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
