Hey guys up for sale i have 4x 17x7.5 inch KR kyowa racing wheels
  • The two front wheels have minimal gutter rash if any and awsome tread with great quality tyres 235's
  • The two rear wheels have some gutter rash but are also in good conditiont
  • The rear tyres are continental 245's with 85% to 90% tread
  • One of the rear wheels had a crack in it and was repaired, the crack has come through since then so it needs to be fixed cleaned up and painted.
  • The wheels are off an r33 gtst and they look awsome for 17's
  • They are great for drifting
  • The reason i am selling is i am after some 18 inch wheels for my ride
i am after $400 and im located in Melbourne west
if you have any questions or are intersted call or msg jayden on 0405 422 600
https://www.sau.com.au/forums/topic/355087-cheap-jap-wheels-for-sale/
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
