i got burnt pretty bad on a stock ECU retune by the only place in SA that retunes stock ECU's. paid 600 for it, now the car runs lean on hot days, uses more fuel, has no mid range punch anymore and has less power up top.
pretty pissed off and they dont believe me when i tell em its rooted. so i got no where and have a car that slow and expensive to run.
  • Replies 100
well shaun at boost worx will do safc tune for 145. He is a good tuner so that is a thought.
Mike Cash, i know what u are talkin about, and sense i will ahve the same trouble trying to get my money back. If it comes to it i will use the law... Consumer affairs may want to know about this. maybe u should type up a letter from ur lawyer saying u will take them to court. Most people pay up then.
I know how u feel when u spend all the money u save up, and now think that its turned to absolute shit.
If you wanted to go to consumer affairs, or min of fair trading, first you need to get a statement from another shop to say what they would have charged for the work, also, if you didnt get a quote to begin with, you will have nothing.
Unless you have a contract, or quote/estimate, you're pushing shit up hill unfortuneately.
I vote for Shaun at Boostworx too, I am v.happy with his tune and his service, and god knows, I have had alot of different places in Adeliade tune my car:p
So, T-man, are you getting Hiep's SAFC? also, we had a very special sausage for you on the dyno day, just ask Cheeky:)
Well back on topic, im off to the tuners tomorrow again to see if they can fix the problem, if they cant, ill be demanding my money back. Simple as that.
Do u guys think i should take out the spark plugs they put in and give them back so they dont charge me the extra 100? I have a set of Ngks at home doing nuthin.
Hey Bob ;) I'm getting a message from beyond the grave (Crossing Over style :P ) I have a strange feeling that the plugs you run are... NGK copper "V-Power 8" (R5671A-8) Would I be right?
I'd say they are the ones I quoted mate.
I dropped into Tilbrooks late yesterday arvo just to see if Mark maybe had some NGK BRK7EVX's (plugs I usually run - I highly recommend these) as I could only track down 3 in the whole of Adelaide (not an off the shelf plug). He gave me a set of the copper V-Power 8's and said to give them a go, as he uses them in lots of powerful RB's with good results. Even John's motor runs them.
How do you find them on cold mornings? Idle quality? Any fouling due to low initial tip temp?
heheh, well thanks for hijackin my threard everyone
back on topic, matt, u r rite, my afm is maxed out, reads 5.05v from 5500rpm to redline.
what to do...
Of course I'm right! I'm always right :P But seriously... it's a good question mate, what to do indeed!? Have a chat with Nightcrawler (Andy) as he is planning on doing the exact same thing you need... Z32 with Unichip/stock ECU. If it can be done, and who knows? Maybe it can then your laughing. I couldn't be stuffed going down that path, plus Tim (ex RPM owner/boss/tuning guru) gave me an excellent plan B.
I run NGK BKR7E (V-Power), altho they are 1 step hotter than the ones you have, they have not fouled up at all in the last 10,000ks and cold starts are perfect etc. So I would assume the 8s should be ok in most cases.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
