Specs:
Year: 1983
Make: Toyota
Model: sprinter ae86
Engine Bay:
4age (recently rebuilt 3k worth) runs awesome
Pod filter
Thermo fan
Exhaust (sounds awesome)
Suspension/Wheels/Tyres:
Adjustable high and camber coilovers in front
Stiff springs in the rear
Longchamp rims 15x7in +11 (I think that is the right with and offset from)
Good tread on all tires
Drive train: standard Gear box, and dif and brakes but they are all good!!
Exterior:
no rust and straight as!!!!
After market Side skirts and front lip
Paint has faded on roof and boot but other than that the paint is in good nick.
Interior:
beep dish steering wheel
Oil pressure gauge
Engine temp gauge
The interior is extremely neat!
Extra parts that come with it:
Fibber glass front and rear bumper
Full diff (welded)
few mashies/stellies, a few bald ones but some have a heap of tread.
And a box off goodies.
Open for swap with cash adjustment either way hiace van or ute (4x4 0r 2wd)Rego to the 6th 2011, Over all the car is in awesome condition, goes awesome and handles awesome!!!
located in Ulverstone. 0400622682 can text pics
https://www.sau.com.au/forums/topic/355427-for-sale-or-swap-ae86/
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
