R34 GT-T
1999 Nissan Skyline R34 GT-t
RB25DET Neo
Silver
Tiptronic
105xxx K's (100k major service done)
Engine:
K&N Pod Filter
KKR Stealth Front Mount Intercooler
R32 GTST Silvertop Waste gate actuator
Exterior:
Factory Naked S1 bodykit
Nismo Clear Indicators front and sides
Nismo Carbon Fibre PillarGarnishes
Work Anodized Blue Locknuts
Eye lids
Factory optioned Monsoonshields
Factory optioned Xenonheadlights
Interior:
Carbon Fibre CentreConsole
Alpine Head unit & Soundstream Subwoofer
Full alarm system
Interior is immaculate
I have owned the car for over 18months and has been a great car but know my circumstances and priorities have changed so time to sell up
Price: $13,900 ono.
Contact
Lewis – 0432 581 798
Or via PM.
Location - Adelaide.
https://www.sau.com.au/forums/topic/355500-mint-standard-r34-gt-t/
  • 3 weeks later...
  • 3 months later...
BUMP!!
HAD SOMEONE VERY INTERESTED BUT COULDNT COME UP WITH THE GOODS...
BLOODY TIME WASTERS!!
BACK UP FOR SALE MAKE AN OFFER!!
Side note - Velo is no longer included and has been sold seperatley
Edited by Volk34
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
