Yep, it's entirely dependant on the store size and sales, but I was stacking shelves at age 17 in a mid-upper size store and that's what our store manager was on. Keep in mind they have gone and done diplomas in management through the course of their careers, but Coles does pay for this. I got offered duty manager position (2-3 promotions away from store manager) but was attending uni at the time. In retrospect it wouldn't have been such a bad career path, but I was too invested in uni at the time. Supermarkets are very underrated these days (provided you're willing to put in the effort) and people always need groceries no matter the state of the economy :)
Yep, each to their own...some dig the working lifestyle but I'd hate to waste my youth on working too hard...can't get those years back no matter how wealthy you are later on!
Its just like working the mines, the working conditions are sh1thouse, you live rural, have no friends, have no social life but you get the $$$,$$$.
Lifes what you make of it, do it for a few years, save your pennies then do something smart with it
Do heed warning about jobs with demanding hours though...I have friends who work those sorts of hours and not only do these people turn into depressed jerk offs (who never take work off, thank you Kanye West), they lose their friends / social life and become a bacterial part of the company...without realising the transition they've made :(
+1. My motto: Work to live, not live to work. No point earning 140K if you don't have time to enjoy life and the money. I settle for half that and have flexible work hours (to a degree) and time to see friends, family, rest, maintain numerous hobbies, and keep fit.
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
