Selling a Twin 2 and a half inch exhaust system right through that comes out to twin dump pipes. Red back extractor with red back high flow cat converters.
To suit Holden VS or vs statesman
Contact me on 0431065484 throw me a reasonable offer
https://www.sau.com.au/forums/topic/355652-holden-twin-exhaustextractor/
  • 4 weeks later...
