R33 GTR front bar $150 o.n.o
drift steering wheel $160 with boss kit, or without boss kit $100 for steering wheel only. o.n.o
Boss kit for $70 o.n.o
window wipers for front and back $30 o.n.o
drink holder for underneath CD player $17 o.n.o
black smokey side indicators $50 o.n.o
back shelf speaker holder air vents $15 o.n.o
front driver side seat belt buckle $15 o.n.o
back seat belt for middle section including buckle $30 o.n.o
nissan skyline R33 floor mats no drive side mat $30 o.n.o
R33 boot carpet to hide back lights $10 o.n.o
R33 boot carpet right side carpet $ 5 o.n.o
call or text or PM me PH:0413421012
All pick up from ADELAIDE of MARION or post anywhere in AUSTRALIA at the buyer own expensive. Thanks
Edited by MAD R33
https://www.sau.com.au/forums/topic/356505-r33-parts/
