Im selling my Cefiro due to baby on the way and have no more time to finish it. The car runs and is about 95% done. Currently unlicensed, but was licensed in QLD.
RB25DET with VG30 turbo and HKS actuator
RB20 gearbox
Front mount intercooler
3" front pipe
3" high flow cat
HSD coilovers
R32 brakes all round
5 stud conversion
Adjustable castor rods
18" Vienna deep dish wheels - 9" front & 10" rear with 4 brand new tyres
Custom wide body & Uras kit
Car needs some body work as seen in photos.
Comes with good dash and interior.
Comes with 3" CAT back exhaust, needs slight modification to fit.
$8000
Can supply RB25 gearbox for an extra $1000
Contact 0400 070 188
Garry
Edited by ceffyrb25
https://www.sau.com.au/forums/topic/357206-fs-wide-body-cefiro/
  • 2 months later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
