Hi all Im chris!
Im a qualified mechanic have always been playing around on jap cars.
So I cant get my 200sx running right...
Its a ADM S1 S14 200sx 1995 Manual
Previous owner blew up the engine, got an engine swap done and has not
been running right since.
PROBLEM
When you drive the vehicle it bogs down and drives like its lacking power.
Were talking like it drives like a naturally aspirated four cylinder with no power!
THINGS IVE DONE TO FIX IT
engine compression test - 150psi all round ok
checked cams and reset camshaft timing - ok
carried out major service all oils & filters spark plugs etc - ok
checked ecu wiring and repaired "had ems stinger piggy back before hand" - ok
checked for ecu codes - ok
air flow meter - replace and check wiring ok
fuel pump - replace and check wiring ok
fuel line - replace and check ok
fuel pressure regulator - replace and check ok
fuel rail and injectors - replace and check ok
ignition module - replace and check ok
turbo - replace and check ok
vaccum/boost leak - secured and checked all intercooler hosing and carried out leak test ok
camshaft position sensor - check wiring set with timing light according to repair manual
check turbo intake hosing for sucking in - repaired and checked ok
So in a nutshell i have put the vehicle back to standard from what it was.
Ive checked and done most things that i can think of and the problem is still there.
THINGS LEFT TO CHECK
Blocked cat/exhaust?
Fried ecu computer?
Ecu computer wiring earth and wiring?
Looking for computer and going to unbolt exhaust to check soon!
NOTE - checked my vin with nissan parts system i need a
WF 23710 74F01, WF 23710 74F02 or WF 23710 74F03 ECU computer.
They are hard to come by!!!
Anyway if anyone has any ideas I would really really appreciate it.
Ill take any help i can get!
Ill post up a pic of my girl so this thread isn't so boring for you guys/gals!
Also got a pic of the inside of the ecu can anyone tell if its been remapped?
Attached thumbnail(s)
Hi all Im chris!
PROBLEM
Fried ecu computer?
no need to double post!
it's running smooth (no miss), but very sluggish?
my guess is you are going to find it is a timing issue.
Are you 100% sure the CAS is correct in the cam (ie keyway not broken?)
Are you 100% sure your timing light is reading correctly? Run spark plug lead from the coil pack to the plug with a timing light attached.
I know you said you checked the timing belt etc but maybe get someone to double check incase you are missing something obvious
are the zorst temps very hot?
Hi Duncan
Sorry about that double post.
Running smooth as!
Fine in neutral idles and revs ok.
Doesn't rev as smootly as a friends sr20 though which is strange, only really slightly.
"not noticeable to a non mechanical minded person"
Its just under load that its totally gutless!
Not a timing issue at all
Set the ignition timing three times "im very pedantic"
Used a timing light and followed the repair manual directly
"and yes i did warm it up and set it in base mode before i set the spark timing"
The timing light im using is a $1200 one i borrowed from work.
It does use a lead you bridge from the spark plug to the #1 coilpack.
I got help with the camshaft/engine timing followed the repair manual
and triple checked through the forums that all the teeth line up and the cams
were in the right position.
Man honestly i don't want to run the car to much the way it its to even think about heating up the exhaust!
The exhaust will be taken off soon and checked. Its a stupid one piece turbo back :(. Im going to angle grind it right before the cat!
Thanks so much for your help mate!
-Chris
hmm well if it's not rough, and it's not timing...
does it actually make boost? maybe the turbo is missing a compressor wheel?
if not that....breathing problem - is there a major restriction in the inlet or exhaust? blocked cat or maybe pete helped you with the motor and left a rag in the intake?
yeah boosts fine
i guess its not so much rough its more or less powerless or boggy
im about to check the cat
redid all of the intercooler hoses so thats sweet
redid the turbo intake pipe so it wouldnt suck it
im checking the ecu earths now
going to check the knock sensor and wiring to
it really feels like a afm problem but its not! hmm
keep you posted
thanks for your help
thanks for the ideas
good news heres the update
Rather then testing the sensors
i tested the wiring input into the ecu!
TEST
ecu earhts ok
ecu powers ok
Pin 30 boost, tps and water temp sensor ground. No earth? NOT OK?!
knock sensor pin 23
was 2v
spec 2-3v OK
camshaft sensor
180deg signal pin 51,41
was 0.5-0.6v
spec 0.3-0.6v OK
1deg signal pin 52,42
was 2.3v
spec 2-3v OK
water temp sensor pin 28
was 3.5v cold and 1.23v hot
spec 2.5v cold and 0.5v hot NOT OK?!
boost sensor pin 35
was idle 1.89v 4000rpm 2.4v
spec idle 2v and 4000rpm 2.2v
air flow meter pin 27
was idle 1.47, 3000rpm 1.95v
specs “engine warm” idle 0.8-1.5v, 3000rpm 1.4-2v OK
throttle position sensor pin 38
was closed 0.6v, open 3.9
specs closed 0.2 to 0.65v, open 4v
oxygen sensor
oxygen sensor signal pin 115
was idle-4000rpm battery volts, still over 4000rpm
specs idle-4000 rpm low volts, over 4000rpm battery volts NOT OK!?
oxygen sensor output pin 29
was -0.02v
specs 0.2 to 0.9v fluctuating NOT OK!?
So its either "oxygen sensor/wiring", "water temp sensor/wiring" or "boost, tps and water temp sensor ground"
Yet to check the wiring and sensors as i just started raining
no garage
Any tips from anyone would be great
ok checked with repair manual
water temp sensor ok
the repco auto encyclopedia had a typo error
oxygen sensor not ok PIN 115
reading battery voltage at idle to 4000rpm
needs to read 0v at idle to 4000rpm and battery voltage at 4000rpm+
unlugged oxy wiring
threw no codes!?
did not make any difference
re did and checked oxy wiring anyway
tested oxy sensor ok
im beginning to think its really the ecu fried going into limp mode without saying it is
its getting to the point that where im just gonna give up n take it to just jap! :(
Try another ecu 1st. Sounds like u know what ur doing as a mechanic. So dont give up yet.
02 sensors are only used as an input into the ecu when off boost. So i doubt that is ur answer.
Check the cat now. As that will cause all the symptoms u have described.
UPDATE!
All sensors are ok and in spec
Just got the new ecu computer from "midnightmods" cheers for that
computer works fine but i still have the same problem
ok so i unplugged the throttle position sensor to set it in base mode and took it for another drive
drove slightly better but still gutless
rechecked spark timing with a light ok
took rocker cover off and checked engine timing again timing fine and cams line up fine to repair manual ok
see attached picks
so on piston one top dead center
exhaust valves dead shut are about to open
intake valves dead shut
following the repair manual
piston 1 is dead at the top
left hand "exhaust" cam mark 12 oclock
right hand "intake" cam mark 10 oclock
COULD I HAVE A STRETCHED TIMING CHAIN?
left to check timing chain for being stretched or cat for being blocked
i don't think its the cat/exhaust blocked Ive had my hand close to the exhaust when my mate revs it it seems to flow out fine
hey mate, Ive had the same issue before with one of these, runs fine but no power.
The one I did ended up being a knock sensor, which will test fine but the sensor keeps retarding the engine causing this boggy feeling you get.
If you can l would highly recommend trying another knock sensor and confirming there a no faults in the wiring for the sensor.
It sounds like youve covered every thing but that is what l have experienced with at least one of these cars before.
Hope that helps and good luck
Cheers
Hmm now thats a thought!
Although the sensor may be reading correctly on idle it may be faulty when the car is going
ill hot wire a resistor to be certain of this!
But how come no codes get thrown!? Hmmmm
old nissan computers and some of the sensors wont actually throw a code unless it has a dead short or open circuit, I still have the same problem today with Y61 patrols the air flow meters sh#$ themselves and stop reading but you get no code due to it dosent go out of range, the voltage just dosent change.
Its a strange system but it works, so if you can l would recommend at least trying a knock sensor and see how it goes.
good luck
Ok guys update!
In the process of borrowing my mates cam sensor and timing that the turbo blew up!
It went pop and now whines its head off as well as blowing smoke...
Maybe that was my problem all along, it was boosting but not enough and the turbo may have been working its arse off to get to the right pressure.
It was a second hand turbo from the internet so you cant trust anyone can you...
Ill whack a s15 turbo on now an let you guys know.
Thanks for all your help!
Replaced turbo today
No different!
After hours of tears and ripping out my hair... I thought "spark timing"
Rather then following the repair manual as it says to set the engine in base mode before setting the spark timing, i set it without putting it in base mode.
IT WORKED
FML!
Well at least the car is all sweet and i know it back to front.
Thanks for all your help guys!
PROBLEM SOLVED!
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
