Well mate, if you like, we can do a dodgy, I pretty much have 2 complete piping kits for a gtir, we can always look at cutting them to fit with a shit load of silicon hose and clamps and make "custom made" pipe for it, plus I believe we could mock up some brackets of our own
Thats just asking for trouble, "custom Piping usually ends in leaks and pressure drop due to less than optimal pipe length and bends.
so is it carseldine this week?
Not sure what does everyone want to do? Me I want to play Gears 3 but I have to wait till thursday so I can co-op that shit.
i'm easy, as i pretty much in between both morayfield and carsaldine.
as for the customer pipe, this was basically saying that, if bodo really absolutely wanted to have a FMIC installed with little to no money, i have a FMIC plus pipe that we could cut and patch with hoses, this is by far not the best thing, as like you said would end up in leaks, but would be possible, as bodo would only need to get the hoses and clamps, i can supply the FMIC and pipe work, but in the end it is up to bodo as what he wants, these ideas are purely ideas and quite possibly bad ones, but ideas none the less.
Custom pipping may not be all it's worked up to be, specially if you are joining several pieces (silicone joitns cost). Might as well buy monsta pipping, or search ebay for the right length etc.
FMIC Ordered, hopefully here end of next week!
Anyone keen to make the meet weds/thursday? either of those days is fine this week, but coming weeks i will have to push thursdays (the mises)
im up for capers castledine tonight. a bit of a drive instead of just hanging around moronfield here. hopefullly chris can join us
im aware that doing a bodgy intercooler with far to many joins would be a dodgy. im just intrigued as too how well it can be made to fit. all those piping kits are aluminium arent they?? if so i have a welder that can fix that. :) i dont do bodgy, but if i can make something instead of buying it, i'll always take that option.....either because ima cheap skate or.....i dunno :whistling:. im sure the best possible intercooler piping length is, the shortest possible way. without going to many sharp bends. i'll see what Joe has there, and if its possible it will be a whole weekend project to piece together i think.
Well mate, I'll be going down to the folks not this weekend but the following, so I'll pick up everything I have, that's pipe hoses and cooler, I believe the pipes are not aluminum, I think there some sort or light steel with crome coating, basically the same as what I have on the line.
However, I might go down this weekend and pick them up as the boy is with the grandparents and I have a feeling I'll need to get him, I'll let you know mate, but I think I have enough pipe to do the kit for you
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
