When is the toowoomba dinner :(
Waitcha turn!
If we were to organise dinner up north next week, would you guys be keen?
keen, as long as its wed or thursday
I would be very keen, Where are you thinking?
good question.
Let me know how the range looks been ages since I was out that way last and was just an out right shambles, would love to move back out to blackbutt area :)
young whippersnapper.
Last time I came down the blackbutt range was just before the big wet :) I travelled it many times over a 3 year period. even then it wasnt a bad bit of road....if you didnt find a cattle truck to get stuck behind, even the old kombi was fun to swing up there.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
