Got some stuff I'd like to clear out of the garage, located in Sydney, prefer pickup but will ship at buyers expense.
If you have any questions sms me on 0411 737 298
Item: R34 RB25DET NEO turbo
Price: $350
Description: turbo is in good condition with no shaft play what so ever. Comes with housing etc
Item: Bonnet lip to suit R34 GTT bonnet
Price: $100
Description: Has small amount of white paint on it, which shouldn't be too hard to take off, already covered in primer. Sits on the R34 GTT bonnet to give a GTR look.
Example of one on a GTT
Item: Bolt on spacers from Just jap
Price: $80
Description: 15mm bolt on spacers from just jap, decided to sell it as it made my wheels stick out more then what I wanted. One stud is slightly threaded, won't be hard to fix
Item: 2x Bridgestone Adrenaline RE001
Price: $200
Description: 245/45/18 with about 90% tread left
Item: Racing Hart Type C wheels + tyres (5x114.3)
Price: $300
Description: size are 17x8, unsure of offset, wrapped in Pirelli tyres with roughly 50% tread.
Item: R33 rear interior quarter panel (arm rest area)
Price: $80 for both
Description: Came off a series 2 R33, in excellent condition
https://www.sau.com.au/forums/topic/357561-garage-clean-out/
  • 3 weeks later...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
