Hey guys i have a skyline which i owned for 4 years but i am parting all the parts. i have moved on and dont wish to continue finishing the car off. Getting old so need this car gone.
List of parts on for sale as is.. ALL BRAND NEW PARTS. NEVER DRIVEN. 0KS ON MOTOR..
R33 GTR ENGINE WITH 2.8 TOMEI STROKER KIT
HEAD HAS BEEN PORTED AND BLUEPRINTED. BLOCKS BEEN MACHINE AS
BUCKETS AND SHIMS AND VALVES ALL 1MM OVERSIZED
WELL. BY JHH IN BRISBANE QLD
HKS STAGE 3 CAMS
TOMEI CAM GEARS
TOMEI OIL PUMP
ATI HARMONIC BALANCER
HYPERTUNE PLENIUM AND FUEL RAIL AND HYPERTUNE THROTTLE BODY
SARD 1000CC INJECTORS
T88 38GK 1200HP TURBO KIT (AIR FILTER, BLOW OFF VALVE AND HOSING AND CLAMPS
MOTEC M800 ECU WITH 9 BOOST SWITCH SETTING AND 3 BAR MAP SENSOR
FULL WIRING LOOM FOR RB26DETT ON R33GTST
GREDDY MANIFOLD AND DUMP PIPES
TOMEI HEADGASKET KIT
BUDDYCLUB COILOVERS ALL ROUND
VOLK GTC FACE 2 WHEELS 18 by 8.5 front and 18 by 9.5 rear
FULL CUSTOM KIT
3 INCH HOOKER EXHAUST SYSTEM
PWR 3INCH INTERCOOLER KIT
PWR OIL COOLER KIT
PWR RADIATOR
SPITFIRE COIL PACKS
3 DEFI GAUGES MOUNTED ON PASSENGER SIDE DASH WITH UNIT
APEXI TURBO TIMER
GREDDY PROFEC B BOOST CONTROLLER
2 WALBRO EXTERNAL FUEL PUMPS
BRAIDED LINES THROUGHOUT THE CAR AND UNDERNEATH THE CAR
ROLL CAGE PADDED
RECARO SEATS WITH RAILS
ROCKFORD FOSGATE COMPLETE SOUND SYSTEM
CUSTOM SURGE TANK MOUNTED UNDERNEATH REAR BAR WITH ALL BRAIDED LINES
FROM WHAT I HAVE TOLD. SPEND ANOTHER 10K ON THIS CAR AND U WILL HAVE 1000HP REAR WHEEL DRIVE R33 SKYLINE
THE LIST GOES ON AND ON. THE WORKSHOP HAS RECIEPTS FOR ALL THE WORK DONE TO THIS CAR.
CAR IS LOCATED IN BRISBANE QLD.
MOTOR ALONE WAS 30K TO BUILD. STROKED MACHINE AND PORTED
ONLY SERIOUS BUYERS ONLY
OFFERS
RING ME ON 0423451393 FOR MORE DETAILS
ALL PARTS LOCATED IN BRISBANE
Edited by hungy81
https://www.sau.com.au/forums/topic/357651-r33-setup-for-sale-brand-new/
ENGINE WORK DONE BY JHH IN BRISBANE SLACKS CREEK, QLD
HKS STAGE 3 CAMS SHAFTS
TOMEI CAM GEARS
TOMEI OIL PUMP
TOMEI BAFFLE PLATE IN SUMP
CUSTOM SUMP TO RUN ONLY REAR WHEEL DRIVE
HYPERTUNE PLENIUM AND HYPERTUNE FUEL RAIL AND HYPERTUNE THROTTLE BODY
FULL CUSTOM BODYKIT
3 INCH HOOKER EXHAUST SYSTEM WITH HKS DRAGGER TIP
PWR OIL COOLER KIT
PWR RADIATOR
SPITFIRE COIL PACKS
APEXI TURBO TIMER
2 WALBRO 044'S EXTERNAL FUEL PUMPS ON SURGETANK
ROLL CAGE PADDED
JVC DOUBLE DIN HEADUNIT
TINTED WINDOWS
DOLUCK SIDE SKIRTS
ADR APPROVED FIBREGLASS VENTED BONNET
DOLUCK REAR BAR WITH DIFFUSER
MSPORT FRONT BAR
DBA FRONT AND REAR SLOTTED ROTORS WITH FRONT EBC GREEN PADS
PAINT JOB DONE BY DMD THE IMAGE CHERRY BLACK
CAR ISNT FINISHED YET. SPEND ANOTHER 10K ON THIS CAR AND U WILL HAVE 1000HP REAR WHEEL DRIVE R33 SKYLINE
NEED GEARBOX OFF UR CHOICE AND CUSTOM TAILSHAFT TO HANDLE THAT POWER AND FEW BITS AND PIECES. ALL ADDS UP
OFFERS
CAR CAN BE VIEWED IN PERSON AT 101 MOTORSPORT SLACKS CREEK
Edited by hungy81
Thread closed.
This is the parts and accessories FS area.
If you are selling the car as a whole, please open a new thread in the Whole Cars for sale section, and include an asking price and more information about the car itself.
Asking for offers without stating a price is not permitted.
Thanks.
Admin
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
