Postcode: 2444
Odometre: 80,000 kilometres
Asking Price: $25,000
Condition: Used
Reason for Selling: Not Suitable
Delivery Methods: PickUp
Contact Info: 0467505670
Extra Information:
1992 S13 Silvia, Orange with RB26DETtt conversion
Orange with a very faint Gold Pearl
RB26DETT conversion - 60,000 km on engine
New N1 water pump
New N1 Oil Pump
idle bearing and tensioner bearing replaced
Garret GT2860RS - 5 turbos(rated at 360hp each)
Tomei Adjustable Cam Gears w/ Trust Timing Belt
RB25DET gearbox
OS GIKEN Twin Plate Clutch (brand new, less than 1000km)
KAAZ 2WAY LSD (very Fresh, even have receipts)
SARD Fuel Pressure Regulator
CUSTOM Stainless Intercooler Piping
Twin HKS Intake Pod setup
BOSCH 044 External Pump
External Surge Tank
ASE Polished header tank
TRUST 600x300x115 Front mount
Custom twin 3" front pipe
KAKIMOTO cat back exhaust with Titanium look tip
5 Stud Hubs
R32 Skyline GTST 4 pots up front 2 pots up back
BREMBO front discs
PROJECT Mu Street Pads front
TEIN HE Drift Spec Coilovers
BRIDE ZIEG III low max seats
Matching BRIDE interior trim on doors, glove box, mats & gear boot
NARDI swede steering wheel
SAFETY 21 HALF CAGE
CUSCO strut braces rear
CUSCO Sway bar rear
HICAS Lock Bar
HID Head Lights
Apexi RSM
DEFI White Face Boost Gauge, Oil Temp, Oil Pressure, Water Temp
PIVOT Security Start Button
TRUST Gear Knob
Boot Mounted battery
Factory nismo AERO front bar
Volk/Rays Engineering TE37 Rims
18x8.5 +30 front
18x9.5 +40 rear
With 15mm bolt on spacers all round
GTR Style grill
NO A/c condenser and lines removed
NO power steering
6 months nsw rego, engineered. 225 semi slicks on front and rear, front bar has some paint flaking.
Looking for $25,000, have spent close to 15 on just engine conversion in last 3 months.
Possibly interested in a GTR, or an EVO 7 or 8, maybe an S15 if its nice. hit me up with the offers, cheers everyone
Need a nice stockish daily car that i can travel in for work, or cheap car with cash my way so i can buy a reliable daily and still have a toy
Text or call 0467505670 or email [email protected]
check my topics for pics ect, its LEWYTHEFLYS13 from ns.com old car and its alot f**king faster now, whinging bitch's need not apply
yes in the photo it has a high mount, that was on the rb20, this comes with a rb26 now...
  • 1 month later...
Price drop to $22,000 negotiable
really need this gone, i am extremely negotiable at 22k for that reason.
can remove wheels and seats to lower price further again.
new photos tonight
URGENT
0467505670
Still for sale guys
THIS IS NOT SHOW CAR, please remember this car is 19 years old now.
Built to be reliable, bulletproof and to be driven hard, not to be trailered to car shows .
Must Go
advertise it on boostcruising man u will get heaps more interest- ive had my r32 on here 4 like over a week n only 1 call,, i put it on boost and ive had over 15 calls today.thumbsup.gif
buyer pulled out, to many dreamers out there, Serious Price drop $18500
that is a $7500 price drop since i first advertised car, welcome to any test and inspection i guarantee it will pass, you cannot even begin to gather parts to build this car for that price. it must go as i am seriously close to missing out on buying the car that i want (track only)
0467505670
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
