The Plaque on the Turbos State...
14411-06U00 Which is the Nismo 32 Serial Numbers which Correspond to A/R .42/.64 Housing & 560Ps Output.
But these have been measured by Precision Turbos in Wetherill Park to be same as NISMO RS581 GT Le Mans ~640Ps Spec units. (Balancing Markings Still Visible)
Same Spec as HKS2530 & 2860-5 But Bush Bearing not Ball Bearing,
marginally less responsive for street application but for track application very good as they are more forgiving than ball bearing units and also much cheaper to rebuild should the need arise As BB units are basically buy new turbos minus the housings...
Below are specs of Nismo RS581 GT LM & HKS 2530 (2860-5)
Nismo GT Le Mans (14411-RS581)
Compressor Housing T04B
Compressor Wheel T3
Compressor Wheel (mm) 47.2 - 60.1
Compressor Trim 55T
Compressor A/R 0.6
Turbine Housing T25
Turbine Wheel T25
Turbine Wheel (mm) 47.0 -53.8
Turbine Trim CD79
Turbine A/R 0.64
Cut back 15°
Bearings 360°
As pair ~640PS
HKS GT2530 (2860-5)
Compressor Wheel T03
Compressor Wheel (mm) 47.7 - 60.1
Compressor Trim 63T
Compressor A/R 0.6
Turbine Housing T3
Turbine Wheel GT25
Turbine Wheel (mm) 47.0 - 53.8
Turbine Trim 76T
Turbine A/R 0.64
Bearings BB
As pair ~640PS
These will easily do >400KW as can be seen on RB26 Thread with right setup & tune.
Hope that's enough information but here's a few photos.
They are a bit dusty but they are in great condition with no radial (side) play, thrust (forward/back) play, no scraping & no chipped or bent blades.
Can take close up of wheels if needed
Price: $1400 Delivered for Turbos & Braided Lines (I Payed More My Loss Is Your Gain)
Reason For Sale: Never fitted them up, decided to change plans and bought a set of Smaller turbos to suit daily driver focused set up.
(My Selling History Speaks for itself.)
Contact: PM for Mobile Number.
Also have heaps more parts in my Signature.
Edited by krayzie32
  • 4 weeks later...
Price Update:
$1600 for Turbos and HKS Dump Pipes to Suit R32/R33 GTR
Dumps are pictured below:
Will separate dumps for $450
  • 3 weeks later...
^No, as they have different flanges...
T25 (GTR) vs T3 (GTSt)
not to mention exhaust side 5 Bolt (GTR) vs 6 Bolt (GTSt)...
Anyways still have these...
Perfect for a track beast...
  • 1 month later...
Kinda totally forgot about these..
Dumps Back up for Sale...
$1500 for the Lot
Can't get any better than this.
Edited by krayzie32
  • 3 weeks later...
how would the standed rb26 internals handle against these
and are u open to swaps
Standard internals would hold up just as much as they would with HKS 2530's or Garrett 2860-5's
A healthy STD RB26 would hold up fine as long as you don't push them too hard to too long without regular maintenance.
I'd be interested in swaps for a nice fresh pair of Dark coloured Bride/Recaro Seats & Rails to suit R32/R33/R34 GTR.
All other PM's Replied to.
  • 3 weeks later...
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
