Hey all,
I have a Profeb B/2 installed and currently with a stock intercooler. According to the diagrams etc. i should taking the pressure signal from just after the compressor, but with the stock intercooler, there is a nipple just after the intercooler. As a result, there a bit of a problem with a time delay i think, due to all that air that needs to get pressurised between the compressor and after the intercooler.
However, on Thurs I am gettin a front mount installed, which will replace the piping where that original nipple is, so - should i get the guy to install a hot pipe from the compressor to FMIC pipes (as it is not included in kit), and get him to put a nipple on it? What have you guys done?
Hope i explained that clear enough,
Cheers,
Matt
https://www.sau.com.au/forums/topic/35836-ebc-valve-tapping-point/
Mine took the reading for the ebc from where the stock map sensor is. A t-piece in the middle of the hose from the plenum to the map sensor (near brake booster).
The solanoid then simply fits inbetween the wastegate actuator & where the wastegate gets its reading from which on the lines is on the turbo's compressor its self (from memory) :)
I once had the plenum to map sensor's hose split. Luckly the ebc went in to limp mode and wouldn't allow high boost to be made.
I used to run a Blitz SBC-iD.
cheers joel.
i take the signal for the EBC from a T-piece in the hose from the fuel regulator, which is all cool.
Its one of the 2 hoses that go to the solenoid that i need to worry about. i prolly didnt explain it well enough originally. The hose in question is the one which provides the boost pressure level to the solenoid. On the stock IC pipes, there is a nipple on the pipe returning, but as a result, causes a lag in the signal being received in the solenoid, as their is much air in between.
However, with a FMIC going in, this return pipe/nipple will no longer be present, so the question is, where do I go about getting the signal from?
If no other advice comes, i think i will just get the guy to, if possible, weld another nipple into the stock pipe leaving the compressor side.
Thanks anyway.
I had the same problem with you when i fitted my fmic. What i did was take it to an exhaust shop and got them to weld a small nipple on the pipe after the turbo. In the end he didn't charge me to get it done due to it taking a few minutes and well worth the effort as boost control was so much more accurate.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
