Your dyno graphs on the previous page.. the run where you dropped the cat.. looks like it was going on to make a fair bit more power than the runs with the cat still attached...........
  • Replies 42
I remember now the test was to verify whether the cat was causing a loss in response, so once that was ruled out, Trent abandoned the run.
I will get another run done without the cat but it doesnt look like a lot more does it?? I supposed hard to say where it will end up.
back to back dyno runs with different sets of cams can give some idea of how a certain cam may/will behave but i would not rely to much on the dyno results.
on road or track testing will provide more accurate data imo.
sure if you have two pretty close sets of cam shafts but one set has longer duration then sure.. it may make some more power up high.. BUT many other factors will effect how it performs in real life applications.
lobe profile. ramp rate. small/large throttle inputs. initial rpm/initial boost at point when WOT is applied. load (higher gear/uphill)
as a rough rule of thumb.. bigger duration will offer more top end power but will come at the price of low down response. so then you can play with lift as well. in my case i didnt go to crazy on duration but opted for huge lift. all this was done in the quest to keep the car snappy on the throttle if the rpm's get a little lower but we still needed the thing to breath and bigger lift obviously helps with this also. As far as i can tell.. big lift usually offers wins across the board but comes at the cost of needing to grind some meat out of your head and needing different valve springs.
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
    • Just to get this straight if you turn the splined shaft to the outside, it turns freely but the chain does not move? What happens when you move the chain, does the splined shaft turn? Surely the shaft is snapped, or the chain is seized and it took the teeth off whatever great is behind the steel bracket
    • Good on you for mentioning, that helps as far as other things you might need to check
