R33 Gtr Suspension (Coilovers/standard)
Hey guys,
I'm chasing some new springs and shocks for my R33 GTR. I've currently got some Racing Gear JTC N1 coilovers in it, however they are way way too hard for street use. Definitely would suit a track/drag car.
I'd like something that is height adjustable, but feels somewhat like the standard setup. Otherwise am happy to look into standard shocks with new springs (or something of the like).
Would be keen on swaps if anyone is interested, also can post up pics of the coilovers I have at the moment upon request. Also happy to buy outright for a good price.
Let me know if you've got anything I might be interested in :)
Cheers,
Ash
post up some pics, and the amount of Kms that your coilovers have done,
I might be interested in a swap for my Bilstiens with King Springs in good cond. They are a great compromise between handling and a street ride.
Hey buddy i have Tein Super Street Coilovers for Sale which i got off my R34 GTT, it will fit an R33 GTR also, it is height adjustable as well as damper adjustable, Its a great coilover for the Street as well as the Track.. Im letting it go for $1000, Let me know if ur interested!!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
